cx transmision
Old 03-20-2006, 04:32 PM
christheape
christheape's Avatar
Default cx transmision
I have a 88 crx d16. I am looking at a new tranny. It is a cx trany out of a civic cx .. My car is a stick shift the trany I want to buy is a stick I know Ill have to put in a clutch cylinder to make my car hidro not cable but the question I have is will I need to get new axles?
Old 03-20-2006, 05:10 PM
Kai
Rotorphile.
Kai's Avatar
Your axles should be fine.
Old 03-20-2006, 05:12 PM
Exempt
2 tone Rex
Exempt's Avatar
Not worth the trouble converting from cable to hydro... Specially for a CX tranny... If you want long gearing (more for economy) buy a DX or HF cable tranny, it will swap right in... If u want more performance get a 88-91 Civic/CRX Si tranny (but being a D16 I assume u already have one)...
Old 03-20-2006, 05:16 PM
christheape
I'm not sure whats all going on I got the car for 500 bucks and I'm still trying to sort out whats what . I know the tranny is going and i found the cx tranny and clutch for 70 with a 100,000 mi so i think it's a good deal . I'm still kinda new at this import deal. I just switched from domestic to import about 4 mounths ago so any advise I can get I think will help.
Old 03-20-2006, 05:18 PM
christheape
And I'm not looking for economy i don't care about that this is not my daily driver it's just a project or a toy.
Old 03-20-2006, 05:23 PM
Exempt
2 tone Rex
Exempt's Avatar
Well, unless you can custom fab things yourself, it would cost you more to make this tranny work than to just buy the right tranny and clutch kit... Im pretty sure the mount locations are different, and then youd have to figure out a way to make the clutch pedal engage the clutch... And on top of that, the CX tranny is the bottom of the barrel of the 5th gens, and is the same unit as the VX (has VTEC-E for economy), so its geared more for economy than performance...
Old 03-20-2006, 05:40 PM
Kai
Rotorphile.
Kai's Avatar
The CX trans can hit about 90mph in second gear, its pretty rediculous. Third gear feels like overdrive.
Old 03-20-2006, 05:49 PM
christheape
What I here is one guy saying it's crap then the other guyt saying the gearing is crazy awesome . As far as the pedal engaging the clutch i found a shop to install the hydro kit for 200. The only thing I was worried about was the axles thanxs for the info!!!
Old 03-20-2006, 08:57 PM
Kai
Rotorphile.
Kai's Avatar
Whoever said it is "awesome" is an idiot. The CX/VX gearbox is the worst geared of all D-series manual transaxles.
Old 03-21-2006, 05:54 AM
mistacee
Zc powered ED9
mistacee's Avatar
You can get a 88-91 Civic Si/Crx Si tranny for about or less than $100.
Stay away from the Cx tranny, not worth the conversion.
