thinking about doing an engine swap.. sugestions??
Old 03-14-2006, 07:07 AM
mr.crx
mr.crx's Avatar
without stock motor puts out about 160, if your intentions are to trubo it shoud be no problem to get well over 220 whp with around 5-8k b16 complete swap will run you around 16-1700 shipped. and then you can do major maods once you get it.
Old 03-14-2006, 09:07 AM
Exempt
2 tone Rex
Exempt's Avatar
Originally Posted by lookin4aCrxSi
when i say go nuts i mean puttin everything i can find into my car! and i mean everything... now you said the B16a puts out around 160hp.. did you mean that with or without a turbo on it??
Well, thats not always the best idea... Different engine mods will work together, and some will counteract each other... And some are just pointless on a 220HP setup (fuel rail for instance since the stock fuel rail is fine upto 500HP)... So I wouldnt 'go nuts' just for the sake of going nuts... Just plan and buy according to your budget and goals...
The easiest way to attain 220HP is probably a boosted B16A...
Old 03-14-2006, 09:41 AM
mistacee
Zc powered ED9
mistacee's Avatar
im buying a Crx Si and im thinking about an engine swap and going nuts on it, i have the money but i was looking for sugestions on what kind of motor i should swap and the reasons why and the approximate cost of it. again, im going to go nuts on what ever i throw in this thing so i'm looking for the best engine to work with and an engine i can go nuts with. B16a? B18a?? need sugestions!!
I would suggest a search.
You may have all the money in the world but not enough brains to do a search on a topic that has been beaten to a pulp daily. Tons of info on motor specs and motor combos, what is best etc....just do some research!
Old 03-14-2006, 12:12 PM
RedlineBoyzCRX
EG6
RedlineBoyzCRX's Avatar
If you have the money to put EVERYTHING into the engine, just buy a K20 and put it in, a STOCK K20 with STOCK ECU in a CRX will run 11's.
Old 03-14-2006, 03:56 PM
gingas
gingas's Avatar
One motor people forgot about although cost more ia a B18C1 (Gsr) motor 170hp. You would have money left over for intake, exhaust & headers. Good luck w/ whatever you choose. Another thing IMO is a na motor will always be more reliable than turbo or supercharged.
Old 03-14-2006, 04:05 PM
lookin4aCrxSi
lookin4aCrxSi's Avatar
thank you everybody for your coments back to me!! this will help alot. i got a buddy at work that was telling me today about how he's got a b18a1 in his 91 civic HB n all he's done is put headers, full exhaust, bigger intake manifold, intake kit and sum sparks plugs n shit n has over 190hp already. im thinking about either goin with the b18a1 or the b16a.. still don't know but probly one of the two... how much does the b18c1 cost around by the way????
Old 03-15-2006, 12:50 AM
Kai
Rotorphile.
Kai's Avatar
he's got a b18a1 (...) all he's done is put headers, full exhaust, bigger intake manifold, intake kit and sum sparks plugs n shit n has over 190hp already.
No he doesn't, unless he has a nitrous system or much more extreme internal engine work. A bolt-on B18A won't even be close to 190 flywheel hp.
