What will it matter if I remove the Charcoal Canister?
Old 03-09-2006, 11:38 PM
Kai
Rotorphile.
Kai's Avatar
You can take it out without problems. It prevents pressure buildup in the gas tank while keeping gasoline fumes out of the atmosphere.
I took it out of my '7 and previous Civic using a vacuum cap to seal it off with no problems. If you leave it uncapped, you may experience various problems including fuel "loss" or a rank raw gasoline smell. Sealed off, it will be fine.
Old 03-10-2006, 05:26 AM
RedlineBoyzCRX
EG6
RedlineBoyzCRX's Avatar
I was told by Schmoo to just loop the vaccuum lines, and take it out.
Old 03-10-2006, 11:21 AM
Provocateur
On permanent hiatus
Provocateur's Avatar
Either way will work. As long as the vacuum leak is sealed, it will be fine.
Old 03-10-2006, 05:39 PM
RedlineBoyzCRX
EG6
Thanx, that is what I will do.
