ZC/1.6i-16 Swap Need Help
Hello,
I just purchased a Euro spec 1.6i-16 (D16Z5) engine, I was wondering if there where any sites for the swap to a 91 US Spec DX w/ MPFI conversion already done. Im using an Si ECU, Im not sure if this will work with the swap, I know it would for the ZC but not sure about the 1.6i-16. I have also read about something that attaches to the ECU some kind of sensor or something, and was wondering it I would need it for my swap. I was also wondering what all other parts I would need and if I could use the Si Dizzy. Thanks for the help in advance.
the D16Z5 is same engine as DOHC ZC - Si ECU will work, not sure if Z5 had O2 sensor, but Si ECU will be looking for one - Si distributor will not work - 88-89 Integra distributor will work - for DPFI to MPFI, go here: (you will just need the part about the distributor and CYL sensor connections)
http://www.fourthgenhatch.com/mpfi.html
Ok thanks, still not sure if I need to worry about this extra sensor that is suposed to hook up. I am planning on using my stock exhaust which has a gutted cat, and a tuner type muffler. i am probly going to put a high flow cat in it though.
