D15b
Old 02-13-2006, 06:28 PM
gonedotcom13
gonedotcom13's Avatar
best choice; PR3 or a vtec controller like Field Boxer or APEX
Old 02-13-2006, 06:53 PM
Exempt
2 tone Rex
Exempt's Avatar
The PR3 ECU with not work without being modified... The PR3 ECU runs the OBD0 B16A which has VTEC yes, but the problem however is that the B16A has two O2 Sensors and a knock sensor... Neither of which are on the SOHC VTEC engines... So unless u modify it in someway (getting it chipped to ignore those 2 sensors), you will get a check engine light... Which means no VTEC for joo... Not too mention the cost of buying a PR3 and paying to get chipped vs the cost of a P28 or P08 and running it CORRECTLY are about the same...
Originally Posted by H23A1
im thinking of just swaping a d16y8 into it
Youd probably better off, that 3 stage VTEC is better off in an OBD2 car who dosnt need to convert OBD types... And just plug in the proper OBD2 ECU to make it work... But with the Y8 youll still have the same things to worry about, minus the 3 stage VTEC...
Old 02-14-2006, 11:50 AM
H23A1
H23A1's Avatar
the d16y8 i have comes with everything ecu harness axles goin to come out a 00 civic ex i think another thing . what if i use a p28 what will i have to do and how much total cost do you think it would be
Old 02-14-2006, 03:06 PM
Exempt
2 tone Rex
Exempt's Avatar
Well its easier to convert an OBD0 car to OBD1 than it is to conver to OBD2... So I would use the P28 and convert to OBD1...
