CRX stock ride height
Old 02-10-2006, 06:07 PM
xpman
xpman's Avatar
Default CRX stock ride height
Does anyone know the correct stock ride height for the CRX and how to measure it? Is there a simple way to measure - like maybe from the ground to the bottom of the door or maybe center of wheel to top of fender opening?
Old 02-10-2006, 09:25 PM
jdmeg6hatchy
i
jdmeg6hatchy's Avatar
If your talking about what the cops measure it by, its the front and rear bumper support, In VA it has to be at least 14" in the front and like 16" in the back. I know, Ive been pulled over like 3 times for this.
Old 02-11-2006, 01:14 AM
xpman
xpman's Avatar
I need to know because I'm replacing my shocks and springs and I'm not sure what my drop is now. It's got adjustable coilovers but I want to put lowering springs on instead. I just want to know how low I can safely go with my 17's without having to worry about the wheels rubbing when I turn, etc...
Right now they don't rub and I want to keep it that way.
All the lowering springs I've seen tell you what the drop is from a stock ride height.
Old 02-11-2006, 07:06 AM
jlicrx
jlicrx's Avatar
this might help
File Type: jpg
Old 02-11-2006, 11:39 AM
xpman
xpman's Avatar
Yes it helps a little. I can get an overall measurement from the roof to the ground but I can't tell if my front and back heights are right or not. My rear could be an inch high and the front could be an inch low but the top of the roof would seem at the right height.
Could someone give me a measurement (stock CRX) from the center of the wheel to the bottom of the fender edge in the wheel opening. Front and rear please.
Much thanks in advance!
Old 02-11-2006, 02:35 PM
jdmeg6hatchy
i
on 17s, ehhh. I would say lowering springs rated at a 1.5"-1.75" drop.
Old 02-11-2006, 07:26 PM
xpman
xpman's Avatar
Looks like a good spot for Tein S.Techs then. I think they have about a 1.5" drop for the CRXs.
Old 02-11-2006, 09:30 PM
Kai
Rotorphile.
Kai's Avatar
Really? I have a couple friends with their cars dumped to the ground that haven't been ticketed for it yet. If you've been cited for it, can you list the section of law? It'll be on the yellow slip if you still have it... I'd like to know the section of code to save me the effort of looking it up.
Old 02-12-2006, 05:48 AM
jdmeg6hatchy
i
sure, ill get them. Cops are just looking for something to pull you over for around here, since we have no real crime in the area
Old 02-13-2006, 09:13 PM
Kai
Rotorphile.
Kai's Avatar
Thanks!
For interested VA residents, here it is via PM to me:
#1 -Altered Suspension min. 14". section- 46.2-1063
#2 -Improper/Deffective Exhaust. section-46.2-1049
#3 -Fail to Display front VA State License Plate. section-46.2-711
I've been busted under VA Code §46.2-1049 and §46.2-711 before, but this of new interest to me:
§ 46.2-1063. Alteration of suspension system; bumper height limits; raising body above frame rail.
No person shall drive on a public highway any motor vehicle registered as a passenger motor vehicle if it has been modified by alteration of its altitude from the ground to the extent that its bumpers, measured to any point on the lower edge of the main horizontal bumper bar, exclusive of any bumper guards, are not within the range of fourteen inches to twenty-two inches above the ground. Notwithstanding the foregoing provisions of this section, the range of bumper heights for motor vehicles bearing street rod license plates issued pursuant to § 46.2-747 shall be nine to twenty-two inches.
