car wont start unless i crank it 5,6 times
Old 02-03-2006 | 01:16 AM
90CvcDX's Avatar
90CvcDX
kekeke
well see there is an issue with all my interior wiring which led me to believe why my relay went bad, its all fucked pretty much. thats the best way i can put it. nothing works properly i get no illumination inside except the ac controls and the speedo only cuz i hardwired it to an accessory switch. turn signals, headlights, and all taillights work only cuz some mechanic rewired them somehow, but to get to the point the wiring under the steering wheel is all loose, and the main relay isnt grounded so i kinda thought that could be a problem too... i tried swapping the harness once already and the car wouldnt start period so i had to put the old one back in, which ended up in my fuel pump not responding. pretty much i figure my best bet would be to swap ALL the wiring in my car with a full body and engine harness from an si, thing is this is very hard to find since everyone wants them for engine swaps and things like that.
Old 02-03-2006 | 03:55 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Originally Posted by 90CvcDX
REDLINE, i just checked out your link and thats a nice crx you have there, but is that primer or an actual flat black paintjob? either way it still looks nice, did you accidentally paint the corner lights or was that intentional?
Haha, yea I painted the corner lights, because I changed them out for JDM Black Clear Corners. Thanx for the Proprs on the car. I have done a lot of stuff since then.
Old 02-03-2006 | 03:57 AM
RedlineBoyzCRX
EG6
I went out and bought another intereior wiring ahrness from someone who was parting out their CRX. It has EVERYTHING u need, If I were you I owuld locate one at a Junkyard or sumtihng and then put that beast in, Wa La, perfect.
Old 02-06-2006 | 06:43 PM
crx88dohc's Avatar
crx88dohc
Its probally you Cap and rotor, I've had the same problem.
Old 02-06-2006 | 07:32 PM
90CvcDX's Avatar
90CvcDX
kekeke
It's all good, as soon as i get my tax return check i'm purchasing my friend's civic with an ls/b16 motor swap for $1500 and i'm selling this car for $500 so i'm not all that concerned with it anymore. thank for the great info though, i greatly appreciated it.
