Anyone done crx d16a6 w/ d16y8 vtec head?
Old 01-30-2006 | 04:45 AM
fourdoorracer's Avatar
fourdoorracer
Default Anyone done crx d16a6 w/ d16y8 vtec head?
i was wondering if anyone has put a 96-00 d16y8 vtec head on a crx si d16a6 block. the reason i ask is because i did the compression ratio calculations and have found that it creates a 10.5:1 compression with that particular set up. and i know that adding vtec usually adds about 20 hp but with a high compression i would think u`d get EVEN MORE power. ANYONE KNOW?????
Old 01-30-2006 | 02:43 PM
mr.crx's Avatar
mr.crx
good q1uestion you do get more power i would say about 130 hp with the mini me swap
Old 01-30-2006 | 03:56 PM
fourdoorracer
Default ................
yeah i figured i would come to at least 127 hp because thats what the d16y8 has stock but that is also on with 9.1:1 compression ratio. so with 10.5:1 ( a whole point and a half) more i would figure more but its all theory till i hear from someone thats done it
Old 01-30-2006 | 04:28 PM
mr.crx's Avatar
mr.crx
well thats something i have been looking into doing i just havent had the time to really research it. if you go to search here i am sure that there is something on it. type in mini me swap something should pop up
Old 01-31-2006 | 06:45 PM
fourdoorracer
Default anybody????
come on this is a very popular swap situation i figure there'd be a ton of you that have done this before????????
Old 02-01-2006 | 02:16 AM
crzy000's Avatar
crzy000
yes it does give you more power but not that much. I did that mini swap. with the d16a6 I dyno that and it give me around 100 hp. with the d16y8 head with a p28 ecu. I got about 135 hp. not bad for a mini swap.
Old 02-01-2006 | 06:37 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
If ur gonna swap, SWAP B-SERIES!
Old 02-01-2006 | 06:49 AM
fourdoorracer
135 to the wheels? thats about what i was hoping for. you said you used a p28 ecu right? well if use that ecu and not use a vtec harness but instead use a rpm switch and relay setup will the computer tell the injectors to still send more fuel when the vtec is supposed to be activated?
Old 02-01-2006 | 07:17 AM
mr.crx's Avatar
mr.crx
no. i dont think so. and the mini swap is very popular so i dontthink anybody is going to explain do to that fact i have seen it explained on here before so search and you will come up with something
Old 02-01-2006 | 02:23 PM
flyromeo3's Avatar
flyromeo3
i just did a search and came up with a vast amount of results.
