best motor for a 90 crx
#52
low 12's with what a k&n filter if that car runs 12's
My CRX runs 10's all day long
How convinent that you 13 sec run got taped over
It would run 12's if the trans didn't blow mabye if you knew what you were doing and set the car up right it woulden't blow.
Dosent mater what a car with a blown trans runs because it dosent run call me when you can drive around the block with no problems
#53
i would really like to see a v6 camaro pull 15's in the quarter my si sure in the hell doesnt pull that and i know for a fact i can beat v6 camaro! so check your facts and if you can prove i would like to see that and dont bring me no stock bullshit stats
#54
i would really like to see a v6 camaro pull 15's in the quarter my si sure in the hell doesnt pull that and i know for a fact i can beat v6 camaro! so check your facts and if you can prove i would like to see that and dont bring me no stock bullshit stats factory stats no go.
#55
#56
I still like honda's. :-/
the reason the tranny blew this time is due to blowing out the rear end. not that you even know what any of these mods mean, but let me list them for you, kid:
3200 stall, edelbrock tpi base, slp runners, port siamesed plenum, 58mm bbk tb, ported stock heads, bbk afpr, #24 injectors, chipped ecu, hedman LT headers, no cats, custom exhaust, and some other shit i'm forgetting.
you do the math. my goal was to break 12's with the stock heads, which i didn't get the chance to do since i blew up another tranny and my rear end. after my 3.73's and new tranny is in, i should EASILY be in to 12's.
good luck with your crx and those goals. :reechy:
#57
and if don't believe a v6 manual camaro can hit 15's, go read a little bit on thirdgen.org. it's not all that uncommon.
#59
Boo Boo Kitty F*#k
As a owner of a LS1 TA and have driven a 2.5 (yes the dumba$$ made a 4 banger camero) a 2.8 a 3.4 a 3.8 and a 305 camero I have to say they all suck end of discussion, besides the LS1 it kicks ass.
