Whats The biggest engine that you can out in a 90 crx si?
Old 11-21-2005, 11:09 AM
Danpjack
Danpjack's Avatar
Default Whats The biggest engine that you can out in a 90 crx si?
I got the ZC in there now and some day i'm gunna change it cuz ya its not as fast as i thought. i'm gunna put a turbo on any motor i get but what should i put it on i want the biggest and badest engine that i can fit in my rex...
Old 11-21-2005, 12:20 PM
shady visions
shady visions's Avatar
I'd go LS/VTEC. B18 block. I've read it's good for turbo because of the compression.
Old 11-21-2005, 01:44 PM
Danpjack
Danpjack's Avatar
ya i know about the b18 but i mean like THE BIGGEST like bam thats a big engine
Old 11-21-2005, 02:51 PM
mr.crx
mr.crx's Avatar
a 454 big block if you can figure out a way to get it to work but i dont think that is what you meant. But my assumption would be a h22 but i am sure that has been covered before so try and search for it through out the website. I am alomost positive that its an h22 other wise you have to lots and lots of major fab.
Old 11-21-2005, 05:50 PM
CrxMaggot
CrxMaggot's Avatar
Well, I dunno how much bigger you would want, hah =P
Old 11-21-2005, 06:02 PM
Exempt
2 tone Rex
Exempt's Avatar
The largest you could throw in a CRX and still maintain driveability and reliability, is probably a B20... Some will argue H22, or K24, but those are pretty expensive to swap in, and youll also need serious amounts of fab work, and suspension work...
Old 11-21-2005, 07:11 PM
Danpjack
Danpjack's Avatar
Ya i saw that pic RETARDED! how much do the h22 and b20 cost? i ya no fab work i want it to look the same just be a beast on the inside
Old 11-21-2005, 11:50 PM
CaliDELSOL93si
CaliDELSOL93si's Avatar
if you are going to build an engine up, go with the b20, if you are just gonna plug and play without building it, go with the h22 although, fitting it in will take alot of work, (ie: custom motor mounts, conversion harness, etc...) If you wanted a decent engine that truly is plug and play, think about the first generation OBD-0 B16A. Good engine to build with and play with !!! Anways, good luck with whatever you decide to go with.
Old 11-22-2005, 03:53 AM
RedlineBoyzCRX
EG6
RedlineBoyzCRX's Avatar
Well, are you looking for the greates amount of HP, or biggest engine. If you have the money, I would go with a CRVTEC. If not, DEF go with a K20 Type R. The K20 Type R will blow almost all the engines away. They have so much potential in such a small package.
Old 11-22-2005, 05:11 AM
Danpjack
Danpjack's Avatar
i'm not doing it yet just for when i do i'm want some ideas and this helped thanks guys
