CRX 88 vs 90
CRX 88 vs 90
Ok, so before i do my swap, im trying to decide on which car i should put it in. I own a 1990 CRX si with short ram intake and an exhaust header, and i have a friend who wants to trade me his 88 Si with AEM fuel rail, Intake. Now he needs the camshaft pully to return back to stock (wont pass smog visual) and a timing belt change. Now i was wondering if i should streight up trade him and just fix the problem myself or i should stick with my car and go with the swap.
Well that and he has drum breaks in the rear and my 90 has all around disc breaks. He just NOW told me that his tranmission syncro gear grinds in 3rd gear
Sharkbait OOHAHA!
If I'm not mistaken, the '88 & '89's have the seatbelts built into the door, and the '90 & '91's do not.
In my '89 si sometimes the seatbelts don't retract all the way (old I guess) and occationally a passenger will slam the door shut on the buckle, damaging my door jam
So I'm not a big fan of the seatbelts-in-the-doors. If I had an '90 or '91 I'd keep it. I think what I may do is get a 4-point harness w/ racing seats and get rid of my stock seatbelts, while replacing the door panels with those out of a '90 or '91 :dunno:
89 CRX si, now with b16!
The 90-91 models also have a slightly different gauge panel, cluster bezel(that hood around the gauge panel), and different headlights and cornerlights.
Well i have a 90 and my seatbelts ARE built into the door. The 88-89 Si had the option of having the belts in door or on the car, the 90-91 was standard and the 88-89 had rear disc breaks also as an option, and for the final years it was standard.
