Does anyone know if they make an O2 Simulator for OBD0 B16?
Well, I want to get all my codes fixed on my car right now, Just so I feel like there is nothing else wrong with my car. I am currently throwing a TPS code, IACV code, and an O2 code. I am going to get my mechanic to fix the TPS thing. And I am going to buy another IACV just to be sure. But I just want my check engine light to go off. That is why I was wondering if they made an O2 simulator that I could plug into the O2 plug to get rid of the O2 code.
I'd save the mechanic bills for something harder you can't do yourself.
On permanent hiatus
Why don't you fix the problem instead of bandaiding it? If you are running a test pipe, put a cat back on. Unless you have a chipped ECU that has open loop disabled, you need to have that O2 sensor there and functional or the car will run poorly.
But to answer your question, I am sure that the O2 sensor simulators are universal.
