ZC vs D16Z6 swap
ZC vs D16Z6 swap
I need a new engine for my 1991 CRX Si. B/C of limited budget I am looking at a ZC(DOHC non-VTEC 130hp) or a D16Z6(SOHC VTEC 125hp). I need some recommendations between these two engines. Can anyone give me some feedback.
Originally Posted by teg92
you just want an engine swap or do you plan on turboing or building it up?
Boo Boo Kitty F*#k
Originally Posted by jlicrx
DOHC ZC will be the easiest - also better performance
Originally Posted by daveb91
Might be the easiest but better performing I dont know. The Z6 definately has at least twice the aftermarket support so its up to you.
Thanx for all the input guys. I will go with the ZC. It is a easy bolt in swap which does not require a new ecu, axles, ect. Probably the cheapest for the budget as well. Thanks again.
