Highest Compression Pistons for a B16a
What are the best High Compression pistons for a stock 81mm bore B16a. How high can I get the compression? i am looking for rod and piston comnos. But any help is welcomed.
been there done that
ctr's will put you at 11.9-12:1 if you want to stick with oem pistons. companies like wiseco, arias, cp, and je have pistons with whatever c/r you desire. if you have access to 93+ octane, you can do 12+:1 with good tuning. and of course cams that would benefit from compression that high.
