Main Relay?
If you got em, burn em!
i had the same problem -
my main relay WAS bad but my injector was ALSO bad so replace both.
https://www.honda-acura.net/forums/s...d.php?t=200085
89 CRX si, now with b16!
Originally Posted by Jigga JJ
sometimes you get that from a faulty injector....the injector could be leaking......or not spraying correctly.usually when code 16 hits.its means what it says..are you running Dpfi or Mpfi?
Sorry, i meant mpfi.
yeah man its definatley at least one of the injectors. either buy some or go to a junk yard and replace em. check the plastic harness part on the top injector make sure it didnt break or anything.
After driving the car today and yesterday with the new main relay installed, I don't have any starting problems, or hesitation. But OCCASSIONALY my CEL will pop on and when I hit a violent bump or slam the accelerator, the car jerks back and forth like i'm hitting the rev limitor, then goes, and CEL turns off.
By now, I'm pretty certain it's the injectors. They're probably not spraying correctly.
I wanted to also add that I found these remanufactured fuel injectors for $35 each, http://www.nopionline.com/nopistore/...0%20CRX%201991 they're from Nopionline. I was shocked because most part stores have them for seventy. What you guys think? About $160 shipped for all of them!
