91 civic dx 1.5l
BLOW OFF VALVES RULE
Just Make Sure It's Getting Frie To The Plugs Frist Then MoVe On TO The Dizzy It Could Be The Modgle In The Dizzy Or The Coil If It's Not Getting Frie .......or The Plugs Could Be Fouled Out ......check These Thing ...... :noes:
sorry, not trying to steal your thread, but I have the exact same problem.
I'm sure mine has more to do with wiring though, yours may be clogged filter or lines.
Speaking of which, where would I listen for the sound of the fuel pump at? I want to make sure it's not something fuel-related (I just cleaned out my intake/fuel rail not 2 months ago.)
Under Construction,always
The fuel pump is behind the driver's seat, under the backseat(if you have one).If you put your head up to it, you'll hear it hum for a few seconds prior to ignition.
