Leak down test & competion test ??
Cylinder leak down test and competion test how do they work ?? how much PSI am I looking for in a B18A/B ?? what good and bad.
And with the Cylinder leak down test what am I looking for I have never seen one done befor
Compression Test:
objective of test is to test the compression in each piston...it is very limited b/c it doesn't figure in several variables
Leak Down Test:
the leak down test forces air via a compressor through the sparkplug hole...this test allows you to crank the engine slowly and watch the gauge through its whole motions...once you find a leakage area you can then just look and listen for where the problem is
http://type2.com/library/engineg/leaktst.htm
http://www.xs11.com/tips/misc/misc3.shtml
Leak Down Test:
the testor....can you just "rent" it from Autozone or do you have to buy one? how much are they to buy?? It probably wouldn't be bad to have regardless, but I'd rather just try it out first!
CiViC2nR86
4
11-14-2003 03:21 AM
ucipreludebebe
07-15-2003 05:00 PM
