Rebuild or ZC
i would go zc, are you going to do it yourself?? a rebuild will just give you a stock crx why not just go for the extra horses, your gonna spend the money, and do the work(if your doing it yourself) either way, why not get something out of it?? the zc is the engine that should've been in the crx anyway.
Boo Boo Kitty F*#k
I would rebuild add a cam from exospeed and some d16a1 pistons. It would be a very cheap rebuild and be better than a zc because the only ZC you will find these days are ragged no matter what the importer says.
Under Construction,always
I would go with the rebuild myself, unless you're going to get a B-series or H22, something like that. Build & upgrade the SOHC with good parts, and you'll probably smoke people with ZC's.I just like going with the SOHC because it is such the "underdog".
