Is a k-series motor a smart engine swap for a crx?
Originally Posted by Pete
if you want a K-Series motor, buy an RSX or new Si. If you're going to have a brand new motor, you might as well have the rest of the car to go with it.
That's why.
true. but i'm sure there are ways to cut the cost down. You don't need to use the k20a specificly. you can use others. Plus, other people spend money on b18c swaps with the same amount of money. So, are there any other reasons as to why?
Originally Posted by UltimX
Haha, is that it? You could say the same thing with the B series swap but the same things apply. I'm looking for a better explenation then just get a new car.
If you put a type r motor in a CRX/EF, you might as well have saved up for a Type R.
I researched the K Series engines before i even started looking at this board or thinking about putting a B series engine. I was dead set on it, had money saved up and everything, then I started reading about people having problems, too much conversion, not being able to find knowledgeable people for the swaps, etc. The swap seems to be more of a hassle than actually buying an engine.
In my opinion, though I haven't swapped a B in my CRX yet, I think it would be a lot easier, effecient, and cost-friendly in my case, and probably most peoples' cases as well.
PS. In the future I plan on getting rid of one of my cars for a RSX-S or Ford Focus SVT.
Aside from these reasons, i was looking for more of a technical reason like r/s factor. K20a head out flows the b16 by a lot. I wasn't concerned about the cost or difficulty factor because thos can always be delt with. Besides, the b series type r engine is about 5k, another 11k and then you got yourself a type r. To each his own. If you don't want
Working on project CRX Si
Originally Posted by sherwood
rather because they ARE the new b-series
be warned though, itll run you beaucoup money for putting it the crx
