I'm Back with a dumb question
Old 06-22-2005, 05:22 PM
Exempt
2 tone Rex
Exempt's Avatar
^ Definately a viable solution as well... The piping and silicone couplings are easy enough to find I would think... Then just slap on a K&N filter...
Old 06-22-2005, 09:54 PM
VTEC-Power
VTEC-Power's Avatar
I thought the D Series intake are 2.5" and the B Series are 3"
Old 06-23-2005, 12:21 AM
Pete
Civilian
Pete's Avatar
Note the piece that is tightened to the throttle body with 2 metal fasteners. It can be tightened or loosened to fit the different applications. However, I am not sure if the inlet diameter of the kit made for the B-Series is wider in diameter.
Old 06-23-2005, 10:44 AM
ED9man
driver
ED9man's Avatar
I put my battery in the back when I did my swap.
Old 06-24-2005, 01:30 AM
Pete
Civilian
Pete's Avatar
I will probably do that eventually if I go the boost route. What do you rate the difficuly of that project on a scale of 1-10 (1 being uber easy)
