what injectors can i use
Rotorphile.
You can use any Honda injectors (or any other brand's top feed injectors of similar design) provided you wire in the proper clips and use a resistor box for low impedance injectors or no resistor box for high impedance injectors.
I'd recommend staying with 240cc injectors from a B- or D-series engine. Anything larger will make the car run rich without some sort of fuel management.
