How much power would I gain?
Old 06-08-2005, 10:22 PM
gordis
gordis's Avatar
Default How much power would I gain?
How much power would I gain if I added these:
Underdrive Pulley (AEM)
AEM Adjustable Cam gears
8.5mm Wires
Header
2.5" Pipeing, HighFlowcat, Greddy Muffler
Cold Air Intake
Accel Upgraded Fuel Injectors
Old 06-08-2005, 10:44 PM
spazz0nater
i wanna go fast
spazz0nater's Avatar
15hp
Old 06-08-2005, 10:55 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
Not much.
You don't need larger fuel injectors for a stock motor.
I would only recommend the cam gears if you had cams. New spark plug wires won't do anything unless you need new ones, and in that case, OEM are the best.
I would just save your money up, like I said in your other post, for some worthwhile mods. Half of those are completely unnecessary.
90civic_Si
90civic_Si's Avatar
depending on if all the stuff that you are putting on is NAME BRAND LIKE AEM DC SPORTS GREDDY.. all that good stuff.. then prolly about a good 30 to 40 hp.... when i added my headers.. resinator w/2.25 piping. and n1 apexi muffler / AEM CAI i added about 45 hp..... but it all depends on the way and how you do it with what kinda sutff.. ya know/
Old 06-08-2005, 10:56 PM
Mkazm83
Snapping bolts
Mkazm83's Avatar
Originally Posted by spazz0nater
15hp
Negative
Old 06-08-2005, 10:58 PM
gordis
gordis's Avatar
What would you prefer:
AEM Cam Gears and Pulleys
Accel I jectors
or
ZEX Wet Kit
Aerospeed Muffler
Provocateur
On permanent hiatus
Basic bolt-ons on an otherwise stock motor will not give you 45 hp gains even if they are the best quality out there. You would be lucky to pick up 10hp from those mods.
Old 06-09-2005, 05:27 AM
DirtyHarry
DirtyHarry's Avatar
Default how many miles on the motor/car/tranny
how many miles you got on that beast?
Old 06-09-2005, 05:50 AM
Fire
wanna run
Fire's Avatar
Originally Posted by Shmoo
Not much.
Listen to this!
nope
save your money for cams, go ahead with the basic bolts IM TB header exhaust, then if you truly want real horsepower look into turbo or block and head work.
Old 06-09-2005, 08:02 AM
Snoopy
been there done that
Snoopy's Avatar
what the hell have you been smoking? do you believe everything you read in magazines?
