Underdrive Pulleys or Cam Gears?
Old 06-07-2005, 04:46 AM
Fire
wanna run
Fire's Avatar
Originally Posted by Shmoo
Money = power.
Without money, you shouldn't even be modding. Save your money for gas or something useful. Don't blow it on useless shit like pulleys and cam gears when you don't need it.
I am just saying that modding just to buy more useless shiney parts isn't a good idea. Do some research, save up your money, and modify when you are ready, educated, and financially responsible to do so. For now, just keep the car well maintained so that when you are ready to do some serious mods, the car will be in good shape.
listen to the bird
Old 06-07-2005, 06:49 AM
Pete
Civilian
Pete's Avatar
You should invest in making sure your car is well tuned and up to par in the maintenence dept before doing any mods. Than you will have a solid platform to work with.
Edit: Reading > me h:
Old 06-07-2005, 07:04 AM
spazz0nater
i wanna go fast
spazz0nater's Avatar
i say fuel rail, cams, bigger throttle body, when you have the money maybe rebuild the bottom end with ARP bolts and h beam rods to make it spin faster.
Old 06-07-2005, 02:08 PM
VTEC-Power
VTEC-Power's Avatar
go to ebay they have a lot of cams
Old 06-13-2005, 02:29 AM
twinring
twinring's Avatar
stay away from those underdrive pulleys. esp. the ones that go on the crank.
If you take off your harmonic damper and replace it for an underdrive pulley, you will have a crank pulley that doesnt dampen any harmonic frequencies that damage your oil pump and engine. So that 7hp increase will come at the price of longevity.
