Help on Clutch upgrade
Could use some help on a clutch update. I am going to upgrade my clutch on my 88 CRX si with a D15B to a stage 1 90-91 clutch. I am also upgrading the to a lightweight Flywheel. Is there anything else I will need other than the Clutch Kit and lightweight Flywheel?
Thank
88REXer
Thank
88REXer
technically a clutch kit should come with the throwout and pilot bearings and a clutch alignment tool
a lot of times when I do a clutch i also replace the flywheel and clutch bolts if they look heat stressed or stripped (make sure you torque them to spec too)
clutch upgrade...
Thanks guys.
I checked and the kit I bought and it comes with everything:
Pressure Plate
Disc
Throw Out Bearing
Pilot bearing
Alignment Tool
8lbs Chromoly Racing Flywheel
I'll have the guy who is doing it for me check the bolts too.
Pressure Plate
Disc
Throw Out Bearing
Pilot bearing
Alignment Tool
