rear disc swap
i wanna go fast
rear disc swap
I know for the swap they need to be out of a 93 integra, the arm rotor and caliper, and the valve, but will i need a new master cylinder? It's going into a 90 civic hb.
parts you will need from a 90-93 DA integra
Rear trailing arms
e-brake cables, (not sure of what year or model, look around, there are TONS of posts on rear disc conversions)
40/40 prop valve
15/16 master cylinder and brake booster
some say you dont NEED the bigger master cylinger as long as you get the 4040 prop valve, but if your going to do anything do it right. The bigger MC will mean less pedel effort and more clamping power.
Rear trailing arms
40/40 prop valve
