Question I need answered fast!!!
2 tone Rex
I should work... The kit people buy from Greddy to put on a DOHC ZC is usually from a 92-95 Civic EX/SI... And since the SOHC ZC (D16A6 basically) is the same manifold (mount wise) as the D16Z6, it should work...
The guy responded saying this
"all the d16, zc, d16y8, and other variations of the 1.6 have the same exzact exhaust manifold pattern, meaning u can inerchange , this means that if u have a 87DOHC 1.6 and a 95 SOHC 1.6 the exhaust manifolds will bolt up to each other, turbo variations and interchange ability has nothing to do with it, the motors r the same cubic inchs, that dosent mean that the heads flow the same it just means that u have the same volume of air going thru the turbo and almost the exzact results on DOHC and SOHC, I have had this same kit on both sohc and dohc aplications and honastly i could not tell a diferance"
if the manifold was made to match the D16A1 head (which is the engine in the picture - not DOHC ZC) it will not match your D16A6 head - the exhaust ports on the D16A1 as well as on the DOHC ZC are about 4mm higher in relation to the mounting bolts than the D16A6 - might be possible to match them, but depending on how it is made, it might not
I looked up some info and I beleave it fits because look they are selling a turbo kit and look at all the engines it fits
92-00 Civic (D Series Motors)
92-00 Civic (B Series / H22 - Hybrid)
88-91 Civic/CRX (D16/ZC)
88-91 Civic/CRX (B Series Motors)
94-01 Integra (ALL)
90-93 Integra (ALL)
Del Sol (ALL)
94-01 Integra (ALL)
90-93 Integra (ALL)
Del Sol (ALL)
2 tone Rex
It will bolt up... But hes telling u there will be that small over lap, where the manifold dosnt cover the whole hole... So it wont be 100% efficient... But it will bolt up... And yea, a B will not fit a D and vise versa...
