CRX problem(please HELP!!!)
my rpm's go crazy around 3000rpm or if i try to accel. hard. it's kinda hard to shift into gear alot of the time. when i let go of the clutch pedal in nuetral it make this noise like it rubbing on something but if my foot is on the clutch it don't do it. it will not burn out or anything and it also jerk while i'm driving when the rpm gauge start acting funny. i adjusted the clutch but don't know where esle to look. can someone please help
Could be a bad throwout bearing. If your tach is not reading properly-that is a sign that simething is going in the distributor. The dizzy is not hard to replace, btw. You will need a timing light for that. Before, spending money on a new one-check for ECU codes just to be sure. You can also take the cap off and see if there is a brownish film on the inside of it and on the internal parts-the bearing does this and it is asure sign of impending failure.
Good luck with this.
