tranny leak!
tranny leak!
Ive had my crx for a month now and I can't fix the damn leak, Ive got new axles and Ive changed the axle seal about three times , but it doesnt fix the leak, does anybody know what can be wrong?
A few months ago, someone on this forum mentioned the bearings holding the differential wear out at around 200k miles. A bad differential bearing means the differential ends, where the axles are inserted, will move around instead of staying dead center relative to the axle seals which results in a leak. (I know because my transmission needs the same repair; the driver's side seal leaks; it's new; I replaced both axle seals when I did the clutch about 1k miles ago.)
He also said that it is possible to replace the differential bearings without removing the transmission.
That could be your problem.
