Help with my H22 in my 87CRX....PLEASE
Old 05-02-2005, 06:02 PM
Kai
Rotorphile.
Kai's Avatar
Originally Posted by NXlude
There is so much bad info here its crazy!
Oh boy, you've come to add more!
First, H22 is only 40 morre than a B series motor. So that isnt an excuse.
Considering how much heavier the B-series already is over the stock D15A3, and it's going into a sub-1800lb chassis, yes. It is.
2nd an H22 rex handles just fine (although you need to put heavier springs on it for the extra couple of pounds. $150 from progress tech)
An '87 is a third generation car. It has torsion bars in the front, not springs. You'd have to swap in heavier torsion bars from OPM motorsports.
Third, although you do have to weld the mounts in, you have to do no cutting to get it to fit. You have to switch to an Sir style hood and thats it.
A B-series engine barely fits into an EC, a H22A is going to take some cutting... getting axles that narrow is going to be hell.
So far I know of 3 guys running custom setups with h22efs, they are all stock motors with minimal boltons and all run low 13s on street tires and 12 all day on slicks.
An EC can do that with a B-series.
Old 05-02-2005, 06:11 PM
ED9man
driver
ED9man's Avatar
Why are you not a mod for this forum?
Old 05-02-2005, 06:59 PM
Kai
Rotorphile.
Kai's Avatar
Because I don't currently own a Honda? Because the OG's don't like me? Because I'm a "big fat meanie-head?" Perhaps I've never been nominated? :dunno:
Old 05-06-2005, 06:57 PM
spazz0nater
i wanna go fast
spazz0nater's Avatar
And yes, I can link you to them if you dont believe me. There are tons of pics showing the entire swap process. But its up to you, pay just as much for a b swap and run mid 14s, or weld in 3 mounts and run 12s.
I would like to see the process to do that not to call your bluff but i am doing a h22 swap in my 90 civic hb. And i need to knwo how to do it.
Old 05-09-2005, 11:49 PM
stereo
stereo's Avatar
i've seen a h22 in a 91 civic the lower front crossmember had to be replaced ,frame cut beat back on both drivers and pass side, mounts welded in , had the clutch master cylinder had to be installed inside of the car ..
Old 05-10-2005, 12:01 AM
wow this is an old thread, BTW i got to see and talk to the owner of that crx.... he said it runs 14s-15s.... on the track... he doesnt have slicks for it and the thing does a burn out through the entire 1/4 mile....
as already stated go with a B or turbo D
Old 05-10-2005, 08:17 AM
spazz0nater
i wanna go fast
But price wise the h22a is cheaper then a b18, and you can drop a h22a in and do 12's
