90-91 teg parts on 91 civic hatch.
Old 04-01-2005, 07:30 PM
Mackenzie C
Mackenzie C's Avatar
Default 90-91 teg parts on 91 civic hatch.
what can i swap from a 90-91 teg to my 91 hatch besides the motor? and for the motor its a obd0 so wiring should still be easy right?
Old 04-01-2005, 08:50 PM
Exempt
2 tone Rex
Exempt's Avatar
Anything will swap with enough fab work... Seats, dash, ect... Not sure what they have that is different from a Civic hatch, thats worth swapping, as im not too familar with tegs... But for the engine, yes its pre-OBD (aka OBD0), so wiring wont be too bad, and it will be a B series, so you will need b series engine mounts...
Old 04-01-2005, 09:12 PM
Mackenzie C
yeah i would need new mounts and new shift linkage.
Old 04-02-2005, 06:41 AM
jdlhonda
jdlhonda's Avatar
You should be able to use your rear trailing arms to upgrade to disc brakes in the back. I would strongly suggest using the brake booster and master cylinder and the prop valve(if not abs) as well for the brakes. Did this on one of my hatches from my 92 Integra GSR and the brakes are awesome no more excessive pedal movement, you want brakes you get em very quickly.
Some of the suspension pieces may work too.
Old 04-02-2005, 09:52 PM
Mackenzie C
do the front brakes work? and i could use the hubs right?
Old 04-03-2005, 06:53 PM
jdlhonda
jdlhonda's Avatar
I would search around but I believe you can use the front brakes you need the hubs/rotors and calipers and i believe I saw something about using the steering knuckles from a civic sedan for clearance items. I haven't had the chance to find out as I have all the parts still in the garage for the front brakes.
Old 04-04-2005, 08:03 PM
Mackenzie C
i see. i plan on doin this in the future, get a cheap 90-91 integra and swap everything over to my hatchback.
Old 04-04-2005, 09:09 PM
jdlhonda
jdlhonda's Avatar
Well in June when autoxing dies down a little bit for me after finally starting up again here in April. I maybe swapping over the full brake systems. I'll post up with pic's and whatnot if I do it.
Old 04-05-2005, 09:09 PM
slammed91-hatch
slammed91-hatch's Avatar
you can use the integra shift linkage and shorten it. you can use the steering wheel, seats, springs, shocks, you need the ecu, speedo cable, axles, possibly map sensor. just throwing down what i kept when i did my swap.
Old 04-06-2005, 07:55 PM
Mackenzie C
i see. yeah i think ill do most of that stuff.
