How many more mods can I go?????
Old 04-14-2005, 03:27 PM
  #51
oolong_black01
oolong_black01's Avatar
nitrous!
oolong_black01 is offline
Old 04-17-2005, 10:14 PM
  #52
StreetRacingCRX
None
StreetRacingCRX's Avatar
I do not want to be that illegal
StreetRacingCRX is offline
Old 04-17-2005, 10:18 PM
  #53
Provocateur
On permanent hiatus
Provocateur's Avatar
I hate to break it to you, but the OBX header and bypass valve on your car are just as illegal since they don't have CARB certification numbers or they void current CARB numbers. Nitrous is the cheapest way to add a large amount of power to a stock engine.
Provocateur is offline
Old 04-18-2005, 09:35 AM
  #54
StreetRacingCRX
None
Actuall the bypass valve and the header due have carb numbers and I put the stickers by my radiator
Old 04-22-2005, 06:07 PM
  #55
aftershock192
aftershock192's Avatar
First off i didn't read all of the post but here are some suggestion of mine. And a few question
1. intake manifold with a hondata(or copycat) gasket
2. a programable ecu(hondata comes to mind)
3. have you thought about head work port&polish
4. what engine do you have
5. what size are your fuel injectors (if they are making you run rich they are slowing you down)
6. do you even know what that power chip did to your ecu
7. which cam is it
once you figure out some of those things you can make alot more power. i really would suggest a different engine managment because that chip is not doing much for you unless it is tuned for your engine. Also once you know what the ecu is doing, you can do more things like advance your timing. If you want to stay n/a you can always shave the head to increase compression ratio without buying pistions.
Going faster doesn't always need more horsepower. Have you thought about making your car lighter. Unsprung and rotational mass is more important then body mass. Also which tranny do you have, your missing out on better gearing there. Rims can also affect gearing and weight what size are they smaller rims will give you a faster overall gearing along with saving weight.
that all i can think of right know i sure i will post more later
aftershock192 is offline
Old 04-22-2005, 08:25 PM
  #56
Reason
Reason's Avatar
Get some juice!
Reason is offline
Old 04-22-2005, 10:13 PM
  #57
StreetRacingCRX
None
It is a Full JUN Racing ECU, and 350cc Accel Injectors
Old 04-23-2005, 10:38 AM
  #58
Snoopy
been there done that
Snoopy's Avatar
which means absolutely nothing. it is not programmable. you are probably running rich as hell with it.
Snoopy is offline
Old 04-23-2005, 11:20 AM
  #59
StreetRacingCRX
None
It auto detects changes and today I bought a OBX High Flow Intake Manifold and B&M Fuel Pressure Regulator
Old 04-23-2005, 11:34 AM
  #60
ED9man
driver
ED9man's Avatar
I'll bet he doesn't have the head to match. :chuckles:
If he does, I don't see how he is driving on the street.
ED9man is offline
