How many more mods can I go?????
buy a weaponr intake with ram air extension and run it through your grill or bumper,get fuel rail,skunk2 bored throttle body and manifold,high flow cat,short shifter,there are plenty more bolt ons,or bolt offs like ac,power steering
I have a ported out intake manifold with racing injectors on it with a slightly wider fuel rail, I have a high flow cat, and a short shifter, The Injen Cold Air intkae if anything seems like it has made the biggest difference so I don't want to change it but I will look into the ram air extension
Originally Posted by RedlineBoyzCRX
You can put in a fuel rail & a fuel pressure regulator.
VAFC and some profesional tuning will you help you extract what power is potentially still in those bolt ons you have. A friend of mine with the basic I/H/E netted an extra 12 horses with just a vafc and some tuning. Besides, thats why you got the adj. cam gears anyway.
Skunk2 intake manifold & hondata intake mani gasket is good for a few horses.
New Zealand
valve springs and retainers, solid engine mounts for better power transfer, a traction bar, clutch and flywheel, weight reduction, again a better intake manifold and bigger throttle body, hondata, 3 dyno sessions...
