Engine Knocking
Old 03-10-2005, 10:24 AM
1fasthb
1fasthb's Avatar
No problem anytime
Old 03-10-2005, 01:51 PM
Opiate
Opiate's Avatar
don't know if it's the same thing or not, but I have a '97 Civic and mine always knocks in the winter time while warming up. After it's been running for 2 or 3 minutes the knock goes completely away and it's quiet again. It's done that for the last 4 or 5 years.
Old 03-10-2005, 03:10 PM
Ronin
Ronin's Avatar
What is happening with yours is called piston slap. Pistons are slightly smaller then the cylinder they are in . This allows them to expand when they heat up.They are also not perfectly round but are cam ground(i think that is the term) This also allows for expansion when they get warm. That is why the sound goes away when the engine heats up.
Old 03-10-2005, 03:53 PM
augy
augy's Avatar
He's right, but it's good to know that the sound can also be caused by cam-rocker contact points for the exact same reason: their clearances are closed up by the time they reach operating temperature, but until then they smack into each other. Another good reason not to rev hard on a cold engine.
