whining noise coming from tranny
I have an 88 crx si and when Im a low gear I can hear a whining noise when I step on the gas, I have a really bad clutch wich Im going to change out this weekend. Will that fix the problem or is it coming from inside the transmission.
From what you are saying it sounds like you throw-out bearing is really dry. If your going to change out the clutch don't worry about it. Just don't forget to change the bearing
