problems with my 89 civic
Old 03-26-2005, 12:40 PM
Kai
Rotorphile.
Kai's Avatar
See my avatar, just imagine a piston instead of an apex seal. Your engine is toast.
Old 03-26-2005, 01:37 PM
kleski
kleski's Avatar
if you have white smoke it is your coolant getting burnt and bad rings won't be a cause for that so you've also had a headgasket...bad rings will only burn oil (bluish) smoke
Very true but the head was just removed to replace the valves so I think the gasket would not be an issue.
