you guessed it - another starting problem
well, i was looking in the other starting problem posts, but didn't see any like my problem. at first, i started my car with no problem. i saw that my idle speed was high, adjusted it back to 700, np, and turned it back off. then i went to turn it on again, it wouldn't. it would crank and crank. then after a while i tried it again and now the lights only dim, and i can hear the starter click. and thats it. i tried jumping it to my other car, and let the battery charge(just to make sure that the battery wasn't the problem) still nothing. engine won't even crank anymore. i used a voltmeter to the starter, and all the voltage is running through it.
i'm thinking maybe bad solenoid, starter motor, alternator?
please help any ideas very much appreciated.
curbsquirrel
curbsquirrel
