How do you remove door panel from seatbelt?
I'm swapping out an interior on a '90 to a '91 CRX. I can't figure out how to remove the door panel. The seatbelt goes right through the panel. Can you remove the seatbelt easily?
2 tone Rex
There is a plastic peice that the belt goes thru... You have to pop the plastic peice up, and then u will see how to remove the belt, there is a hole there for routing the belt off the panel... But u have to pull that plastic peice up and off the door panel...
