Least expensive, fastest Honda?
Originally Posted by Kai
Assuming you mean a 300ZX, you might as well compair an aftermarket turbo'ed Chevy Baretta to a Corvette. These vehicles are in completely different classes and price ranges.
It depends which 300ZX you are talking about.
The Miata manual isn't that great.
Four wheels what? :eh:
Rotorphile.
Originally Posted by augy
Well, again, the early 90's models are within 1 or at most 2 thou of each other in the used car market around here.
VR4.
Does your RX-7 Have the same tranny as the Miata? Or have you actually driven one?
When you say "early 90's" I think single turbo option late-80's, early 90's body. Those sell for much cheaper then the latest, flush headlight twin-turbo option 300ZX's.Around here, you're lucky to even see a VR4, much less to find one for under $10k. $8k above normal CRX pricing. The 86-91 N/A RX-7 trans and the Miata five speed trans are both of the "M" type. I love my "M" trans, it's just nothing too special (esp. since I have an 87.5+ .697 5th instead of my stock .711 5th. )
... How did you end up with the non-stock 5th?
Rotorphile.
$8000 for a CRX????
Read that again. $8000 more then what a $2000 CRX sells for.I used an N/A S5 (89-91, all .697 5th gear) transmission the last time I replaced mine. All 86's, like mine, and early 87's came stock with a .711 5th gear.
A CRX with a turbo D16A6 would be cheaper and faster.
2 tone Rex
Yea, stock CRX Si has D16A6, and no the D series and B series cannot share turbo kits... I know for one the manifold will not be the same... Not sure what else...
just turbo ur dseries and upgrade ur fuel management and it should last you a while. and if u did blow ur motor a dx or si motor is really cheap. u can prob pick one up for 50 bucks, and youll smash on b16s all day.
Yea. That turbo sounded good until i saw the prices here http://www.turbo-kits.com/crx_turbo_kits.html. 3 and 4 grand. That could easily get me a complete changeover b16a(motor mounts, a/c mount and all), installing it myself.
Registered Rota Dealer
I've seen complete used turbo kits (BOV, IC, Fuel, etc) go for $1500-2000 for D-series. Only thing you would have to worry about is rebuilding the turbo if necessary.
