I Need Major HELP!!!
my car wont go over 2500 rpm's, it has a new distributor but it still trows the same code on the comp., but still at 2500, i think that it might be the timing. Can someone please help?
it's not timing as your engine would shake at idle...all it might be is a vacuum line that is messed up preventing you from revving and force the car in limp mode
what code is being thrown exactly?
the code that the car is throwing is 4 (crank angle sensor) and 7 (throttle angle), but the like i said the distributor is new along with the cap.
