Fuse Problem with 91 Si Civic
What's up fellas, Is everyone ready for the Superbowl? Have a problem could anyone help. This started 2 hours ago. My #1 fuse(turn signals back up lights). I put a new 10 amp fuse in. When I put key in ignition and turn key my fuse blows. I have no interior clock, turn signals doesn't work, gas or temp gauge. What could it be to cause my fuse to constantly blow. All my other fuses are fine. You need turn signals, temp gauge & gas gauge to work properly. You don't think my ignition switch could be causing this. I have no amps. Thanks fellas, Gingas
WOW well here is everything that fuse powers up.
Integrated control unit, combination switch, gauge assembly, back up
lights switch or shift position console switch, clock, automatic shoulder
seat belt control unit, shift lock solenoid, interlock control unit
You may have to start unplugging everything and put the fuse in and plug everything in one at a time untill it pops. That may be the only way to isolate the problem
