gas pedal has too much play
2 tone Rex
Adjust the throttle cable... If u dont know where it is, open the hood, and have someone step on the gas (with the car off), the cable that moves is it... There are 2 bolts that hold it onto a bracket on the intake manifold... Adjust it to take any slack out of it... Careful not to pull it too tight, or youll screw up your idle... Ill see if I can find some pics...
Took some pics of mine...
Blue line is the path the cable takes to the inside of the car...
Close up the adjustment bolts...
