Mini me worth it or not?
I bought my crx si at 100000 miles. The guy just put a new used motor in it. It now has about 170000 and still runs perfect and uses no motor oil whatsoever. I'm fixing to do the timing belt and water pump. Should i go ahead and spend a little more on a used vtec head for this motor while i'm doing this? What are the 1/4 miles times with the stock crx si motor and one with the sohc vtec head on it? I've been wanting to put the b16a in it, but that would be stupid if the motor in it still runs perfect. I've heard where these Honda motors are never the same after taking the motor apart, like removing the head. For example, it will be more likely to develope a head gasket leak or something after doing the mini me. Anyway, question being, should i do it or not? Thanks for any help on helping me make my decision. By the way, my car is loaded down with stereo stuff. I remember when i first got the thing before i put the heavy stereo stuff in it, it would haul tail as compared to now. I may also remove this stuff if i do any more performance mods. It's making me go deaf anyway.
Originally Posted by ED9man
Not really, those motors are a penny a dozen and take a few hours to change. That guy probably picked it up for a couple hundred bucks. It wouldn't be a waste to get rid of it.
Well. From the looks of it, it's either not worth it, or somebody that has one did'nt read my post. If it adds 10-25 horses, it may be worth it, if it's an easy install.
Thanks for the reply. Will my aftermarket headers, or the stock headers, fit this head or not? I'll be sold if i get an answer to this. Also, does the stock intake manifold work with the head? The guy that's selling it is including the intake and headers, but it'd be nice if the stock one's fit the head. Especially considering, i've already got the aftermarket headers.
Don't worry about the motor never being the same, that's nonsense. I'm pretty much an amateur, but I've replaced heads on early CRXs 4 times now. If you're careful and do a good job, the head should never leak (my first one did, but none since). I haven't noticed any difference in performance either.
