Genral but weird and off the wall question
Rotorphile.
Originally Posted by augy
Maybe CA-spec cars are all made in a a special factory? I wonder if non-CA cars are all made in the US of A
I think they switched to an American plant around the time the 6G came out.
Don't anybody freak out because a bunch of Canadians touched your car. :chuckles:
Passing_U_N_A_CIVIC
Now I found this info
D13A2 1.3 8V SOHC 2bbl Carb 1342 60hp@5500rpm 73tq@3500rpm '87 Civic/CRX 1.3 (USA)
D15A2 1.5 8V SOHC 2bbl Carb 1488 76hp@6000rpm 84tq@3500rpm '87 Civic/CRX 1.5 (USA)
D15A2 1.5 8V SOHC 2bbl Carb 1488 58hp@4500rpm 80tq@2500rpm '87 Civic/CRX HF (USA)
D15A3 1.5 8V SOHC PGM-FI 1488 91hp@5500rpm 93tq@4500rpm '87 Civic/CRX Si (USA)
D15B1 1.5 8V SOHC PGM-FI 1493 70hp@5500rpm 83tq@3000rpm '88-'?? Civic
D15B2 1.5 16V SOHC PGM-FI 1493 92hp@6000rpm 89tq@4500rpm '88-'91 Civic DX/LX (USA)
D15B6 1.5 8V SOHC PGM-FI 1493 62hp@4500rpm 83tq@3000rpm '88-'89 Civic/CRX HF (USA)
D15B6 1.5 8V SOHC PGM-FI 1493 70hp@4500rpm 83tq@3000rpm '90-'91 Civic/CRX HF (USA)
D15B7 1.5 16V SOHC PGM-FI 1493 102hp@5900rpm 98tq@5000rpm '92-'95 Civic DX/LX (USA)
D15B8 1.5 8V SOHC PGM-FI 1493 70hp@4500rpm 83tq@3000rpm '92-'95 Civic CX (USA)
D15Z1 1.5 16V SOHC VTEC-E PGM-FI 1493 92hp@5500rpm 97tq@4500rpm '92-'95 Civic VX (USA)
D16A1 1.6 16V DOHC PGM-FI 1590 113hp@6250rpm 99tq@5500rpm '86-'89 Integra (USA)
D16A3 1.6 16V DOHC PGM-FI 1590 118hp@6500rpm 103tq@5500rpm '88-'89 Integra (USA)
D16A6 1.6 16V SOHC PGM-FI 1590 108hp@6000rpm 100tq@5000rpm '88-'91 Civic Si
'88-'91 CRX Si
D16A8/9 1.6 16V DOHC PGM-FI 1595 137hp@6800rpm 108tq@5700rpm '88-'91 Civic/CRX Si (JDM)
'90-'93 Integra LS/RS (USA)
D16Y5 1.6 16V SOHC VTEC-E PGM-FI 1590 115hp@6200rpm 104tq@5400rpm '96-'00 Civic HX (USA)
D16Y7 1.6 16V SOHC PGM-FI 1590 106hp@6200rpm 103tq@4600rpm '96-'00 Civic CX/DX/LX (USA)
D16Y8 1.6 16V SOHC VTEC-II PGM-FI 1590 127hp@6600rpm 107tq@5500rpm '96-'00 Civic EX (USA)
D16Z6 1.6 16V SOHC VTEC PGM-FI 1590 125hp@6600rpm 106tq@5200rpm '92 - '95 Civic EX/Si (USA)
'93-'95 Del Sol Si (USA)
D17A1 1.7 16V SOHC PGM-FI 1668 115hp@6100rpm 110tq@4500rpm '01-'02 Civic DX/LX (USA)
D17A2 1.7 16V SOHC VTEC-II PGM-FI 1668 127hp@6300rpm 114tq@4800rpm '01-'02 Civic EX (USA)
D17A6 1.7 16V SOHC VTEC-E PGM-FI 1668 117hp@6100rpm
111tq@4500rpm '01-'02 Civic HX (USA)
And it says that my D15b1 is 8V but on my engine it says 16V....Does mean anything really...lol....Just wondering!!!
Thanks For All Of Your Help!!!
'88-'91 CRX Si
Considering the facts:
You have an 8V motor with a 16V valve cover and a 1.6 hood or sticker.
Sounds like that Canadian had too much beer and drove into a truck leaving a hockey game. The hood and valve cover got replaced after the accident.
Originally Posted by Kai
North American hatchback production was in Canada through the 4th-5th generation, AFAIK.
Oh, and 91_CiViC_RiDeR, if you're certain that you're in a DX and not an Si with the badge removed (you'll probably see the scarring of an Si badge if your car hasn't been painted after the badge was removed), you may well have a basic non-vtec mini-me swap, which is a DX block under an Si head, which would explain the 16-valve emblem. Remove the valve cover and see how many valves you actually have, and that should settle it.
A way to be certain if you have an Si or not is to read the VIN. I don't recall exactly how to decode it, but you shouldn't have any trouble coming up with a website that will tell you which letter indicates which model variant.
Rotorphile.
Do you know why only hatchbacks were made stateside of the pacific? You'd think they'd save money doing it one way or the other. Maybe hatchbacks aren't popular in Japan?
Passing_U_N_A_CIVIC
Ok well I will have to look at my engine tomorrow to take the cover off to look at the vavles or whatever. As far as trying to decode my enigne number I have tried and I am really confused.... But if any of you want to give it a shot here is my VIN # 2HGED6349MH566348
Rotorphile.
Isn't the B1 the crappy 16 valve from the Standard model? Pretty much the same as the B2 except for a weaker cam and a throttle body that doesn't open all the way, IIRC.
