my temp gauge is out?
Originally Posted by VPUPPY
on some hondas, follow your lower radiator hose(the bigger one on the passenger side of the radiator, next to the drain plug) until it hits the housing(should be the same diameter as the upper one). there should be something that looks like brass sensor that is screwed into the housing and has a connector on it. that is the temp sensor.
Rotorphile.
Originally Posted by Mackenzie C
whats up with that?
If that's the case, the car could be overheating without you knowing it. That's a bad position to be in.
ok i found it. and i let my engine warm up. and the valve cover is hot, but the radiator hoses and that housing thing isnt? but all my heater hoses are hot, the heat is hot, but that housing isnt, whats up with that?
btw, the cheapest thing to replace would be the thermostat.
Originally Posted by Kai
The radator could be clogged, the thermostat could be bad, worst case scenario the water pump is bad. For some reason the water isn't circulating.
i think i do have a leak, shit.
you might want to make sure your gauge is working correctly before you go out and to a water pump. d/l a service manual(@ http://www.hondahookup.com/manuals/) if you have not already and run through some trouble shooting before and verify its a cooling system problem and not electrical(bad ground in the gauges or bad sending sensor).
but, if your certain it a circulation problem just go that route.
