CRX Lowering problem
Sharkbait OOHAHA!
Originally Posted by Joao
Ok I had first hand experience with lowering and cameber kits. First off the frot camber kit on a crx can only be adjusted 1 degree of camber without hitting the control arm. pretty much usless. I tried everything to get it to work. I tried cutting out the pinch weld on the fender...i tried adjusting the control arm...man i tried everything. I ended up pushing the camber all the way negative and calling it a day.
As was posted earlier...its just the price we have to pay.
The rear camber kits work perfect though
The rear was a real camber kit. It wasn't the ones with the bolts and washers. It had the upper control kit for the back with adjustments. The back worked great. The front is where the problems are at. The Front upper control arms hit the inner fender lip only on ethe driver side.
