problems?
TPS Is fine. I don't know why that would be an issue. The ecu isn't throwing a code. I also checked for vac leaks and there are none. I also covered the hole in the TB (side wall) and the idle dropped on start up. After the car warmed up, i tried it again and no rpm drop was noticed. So i guess thats out. Anyone else got any ideas? Throttle cable is fine. Adjusted that thing via helms and there isn't any binding in the cable.
