chevy 350
Old 10-31-2004, 05:14 PM
Crx-702
Crx-702's Avatar
Originally Posted by firefastsi
turbo a b18c5 or c1
Why would you turbo a ITR motor?
Old 10-31-2004, 09:17 PM
Fire
wanna run
Fire's Avatar
"I" wouldnt. alot of people choose to though and it does make a strong motor. If I were to turbo, which i wouldnt, id go non vtec. =P
Old 11-01-2004, 08:37 AM
daveb91
Boo Boo Kitty F*#k
daveb91's Avatar
Enough money (and stupidity) anythings possible.
Old 11-01-2004, 08:45 AM
Pete
Civilian
Pete's Avatar
High compression + boost = :nono:
Old 11-01-2004, 09:13 AM
v8guy
Professor
v8guy's Avatar
You can do it but you need to run at least a 150 shot of nitrous.
Old 11-01-2004, 12:23 PM
Snoopy
been there done that
Snoopy's Avatar
with the right tuning, high compression + boost > low compression + same boost level
Old 11-02-2004, 11:26 PM
augy
augy's Avatar
Right. Boost is a way of compensating for the compression; all boost or a compression ratio does is cram more air and fuel into your same sized cylinder. The only reason to use boost instead of engine tuning to do it is because it's a LOT tougher (and far more expensive) to get equivalent performance all motor.
