whats obd/1/2? what is that stuff?
Old 10-31-2004, 03:08 AM
Kai
Rotorphile.
Kai's Avatar
Originally Posted by PHiZ
Wow, great explanation!!
-PHiZ
Thanks. :chuckles:
Originally Posted by ED9man
they don't even look like plugs?
They look like plugs... you just have to look past the baby flesh hanging on the 20 billion prongs. Never turn your back on an OBD-2 computer, or it will eat you too.
Originally Posted by Mackenzie C
whcih ecu would work for this example application then? 91 hatch + obd2 motor
Simplest case: backdate it all to OBD-0. Use the proper ECU from there.
I need a more specific question, as in which exact engine, and which exact OBD level do you want it to end up. I can tell you right now that you don't want to keep it OBD-2.
Old 10-31-2004, 02:10 PM
augy
augy's Avatar
Originally Posted by Kai
Thanks. :chuckles:They look like plugs... you just have to look past the baby flesh hanging on the 20 billion prongs. Never turn your back on an OBD-2 computer, or it will eat you too.Simplest case: backdate it all to OBD-0. Use the proper ECU from there.
Wow, Kai really doesn't like obd2.
Old 10-31-2004, 02:17 PM
Civic2Scooby
Civic2Scooby's Avatar
because obd2 in terms of tuning etc is the suxor
Old 10-31-2004, 03:58 PM
Mackenzie C
Mackenzie C's Avatar
um...........ok i guess ill change the example to obd1.
obd0 91 hatch + obd1 95 jdm gsr
Old 11-01-2004, 09:45 AM
PHiZ
BOOST GOD
PHiZ's Avatar
I think OBD1 is best. That way you don't have to find an OBD0 vtec distributor.
-PHiZ
Old 11-02-2004, 06:20 PM
Mackenzie C
if you were going to drop a gsr in a obd0 car cant you just use a dizzy and injectors from a 90 integra?
Old 11-02-2004, 07:27 PM
Kai
Rotorphile.
Kai's Avatar
If you want to chop off one of the distributor's legs to clear the VTEC solenoid and are happy with a dist holding on by two legs, yeah.
Old 11-18-2004, 09:51 PM
crxkid
crxkid's Avatar
Default Kai, I need your expertise
This applies to this guys question: I'm swapping a B18 LS motor into my CRX DX. I know I need to convert my dpfi to mpfi, and if I'm understanding your explanation correctly, my car is OBD-0? What is the LS motor and what would I need to do to make everything compatable? Thanks alot for your help.
Old 11-18-2004, 10:41 PM
91_CiViC_RiDeR
Passing_U_N_A_CIVIC
91_CiViC_RiDeR's Avatar
FYI I think there is a section in the FAQ that will explain all that too you...Just thought I would let you know so it doesn't get explained again or do a search on it....Just a thought....
Good Luck on the SWAP!!!
Old 11-19-2004, 12:12 AM
Kai
Rotorphile.
Kai's Avatar
Yes.
An "LS" engine is a misnomer. It can apply to three different engines:
86-89 D16A1
90-93 B18A1
94-01 B18B1
The commonly accepted "LS" engine is the B18A1 or B18B1.
Everything required to convert can be found in a search.
