Z600, anyone?
Old 10-18-2004, 09:10 AM
Pete
Civilian
Pete's Avatar
0-60 in... Wait, does it even get up to 60? h:
Old 10-18-2004, 10:07 AM
Kai
Rotorphile.
Kai's Avatar
Originally Posted by More&Faster
seriously though, are you actually thinking of modding it? seems like a waste. i would just keep it stock.
I'm thinking of restoring the good one, and having my way with the parts car.
0-60 is something like 30 seconds, top speed is around 75mph. :chuckles:
Old 11-19-2004, 06:35 PM
savageangel
savageangel's Avatar
1st gen rx7 rims will bolt right onto the n600's www.tirerack.com has a 175-50-13 inch tire that looks ok on the car, the fronts stick out a lil bit, the handling and stability is like going from night to day. I have done the whole swap for under 200.00 with the help of picknpull. the tires are a little taller but it helps out on the freeway, which is not a place these cars are famous for going anyway! the only downside is your speedo wont be correct anymore, it is geared low enough that taking off isnt a problem at all, if you want the 10'' tires go to your nearest golf cart store they will have dot rated tires that will fit it and go on the freeway at an OK price. Now, the real question is what engine/transmission will swap with little modifications!
p.s, I have paced this lil n600 at 75mph with the new tires and no engine mods it had more pedal left, 0-60 is fine, its past 60 up hill that it has problems :P
