How many miles did you get?...
Not sure what you mean....
Originally Posted by Magik
What color is the smoke?
White = Antifreeze
Blue = Oil
Black = Fuel
I'm assuming it's blue if you're burning that much oil...I'd do a search on here on what causes excessive oil burning and start hunting down your problem...otherwise you will have bigger problems later.
Jason
White = Antifreeze
Blue = Oil
Black = Fuel
Jason
Maintaining the car is great but....
I agree with what people here are saying about maintaining the car and then they last a long time. But unless you're the original owner or have all records to prove its maintenance since it was new then how can you know for certain that when you're buying a used car (especially from a dealer) its been maintained regularly? I treat my car like a new born baby really. If it even makes the faintest noise I take it in, I always get regular tune-ups, oil changes, etc. I spent all this money, while I've owned it, on maintaining it so it would last a long time and now I feel like an idiot. I mean it woulda lasted this long if I hadn't done all I have for it. 165,000 miles isn't that many miles and is average for a 91'. I know Fords & Chevy's (which I think are like a Bic lighter-designed to be replaced every few years) with more miles and way rougher owners. I bought this car with 107,000 miles on it 5 years ago and everyone always says it looks like a new car, one lady even thought it was new! Its in such great shape. But apparently it only looks good and wasn't maintained mechanically at all =(....
Originally Posted by redcivicforever
I appreciate your reply but I don't know what you mean when you say "or later you will have bigger problems" isn't an engine a pretty big problem? I think its the biggest, the most expensive anyway. Do you mean that it might not be my engine? Or are you saying becuz it might be just my rings or something and not the engine? Or I should know what caused this problem to help with my future engine or...??? Thanks again for your help
Jason
But rings cost more than an engine and....
It might not be the "entire" engine...just one "component" of the engine...for example as you've said "the rings". Blowing smoke does not necessarily mean your engine is screwed...blowing smoke is like a scratchy throat or a sniffle is telling you your are getting a cold...but...if you don't take care of yourself and that cold it could potentially turn into pneumonia and you die = don't find and fix your engine problem you "will" need a new2you engine. Start researching the causes of blowing smoke (depending on the color) and burning oil (doesn't sound like you're burning it, sounds like it's going out your tail pipe) and then start diagnosing what is wrong with your baby.
Jason
Jason
91 Civic LX, 1.5L I bought car at 155,000 miles. Just replaced engine at 196,000, engine was going thru quart of oil every 100 miles for last 10,000 before I changed the engine. I took the head off and the valves were burnt on #3 cylinder. I had to clean the spark plug on #3 cylinder every couple of hundred miles as it wasn't burning the fuel. I had 5 psi on #3 cylinder wet. Still got 28mpg even running on 3 cylinders! Wasn't bad for power on straightaways, just had to shift to third gear going up hills. Put another engine in (168,000 on engine) and it runs fine, gets 45 mpg, although the last fill up, I calculated 49mpg (is that possible?). I've read of people getting 300,000 miles on their Honda's though.
Wow!
Did you run it hot ever? If you want your engine to last a long time, you have to keep up the maintenance. Obvious is oil/fluid changes, but the last thing you want to do is run it hot. Even if you run it hot, you fix the problem, and it seems fine, damage has been done.
Do you mean overheat it?
